Linde oxygen regulator
发表于 2021-8-31 23:14:04 | 显示全部楼层 |阅读模式
Here's the question. I have a Linde oxygen regulator which is attached to a Linde W-200 torch with 3/16" hose. The outlet on the regulator and the inlets on the torch are quite small consistent with the 3/16" hose. The outfit is missing the Acetylene regulator. I can't seem to find any regulators with this small outlet size. Does anybody know where to look? Or can you simply reduce down the outlet on a larger size regulator? Thanks
Reply:Or can you simply reduce down the outlet on a larger size regulator?
GMT+8, 2025-12-27 22:24 , Processed in 0.096496 second(s), 18 queries .
