Miller Alumapro push pull gun
发表于 2021-8-31 23:14:03 | 显示全部楼层 |阅读模式
Does anyone know if I can...or know where to purchase the drive motor and gear box gears only for the Alumapro push pull gun. I have several good motors, and gear boxes with bad drive helical gears. Seams to be a waste of money to buy whole new motors and gearboxes...$$$... Any help or suggestions appreciated!6"XX P5P8 6G
Reply:Just for future reference...In case someone else needs this info...I found a manufacturers name and numbers on one of the motors. I will call and talk with them about the gear sets for these motors/gearbox for the Aluma Pro mig gun.Here is the site. http://www.ametektip.com/index.php?o...mpaign=pittman6"XX P5P8 6G
Reply:cool keep it posted i assume miller wont sell you these parts only just the whole shebang ??350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-27 22:22 , Processed in 0.134612 second(s), 18 queries .
