anyone have experience with laser welding?
发表于 2021-8-31 23:14:02 | 显示全部楼层 |阅读模式
I do a lot of laser welding in my line of work. I did a lot welding for fabrication for car stuff in my garage so i took the lead as "they guy" for a all of the welding processes at work. I do a lot of resistance, parallel gap, ultrasonic, and impulse welding.Anyway, a fellow engineer originally designed some hardware to be tigged on a rotary table with pulse and settled with 316L. It was later determined that it was too much heat for the components so we had to laser weld the parts. Unfortunately i never had good experiences with 316L using a yag laser unless the fitment was ultra perfect. I'm talking about a 0 gap press fit. spot size is about 25mils. you can see some of the heat cracks. Mostly due to a poor choice in material for the application. Next time he will know to consult in me before material selection. I will have to go back to tigging the parts after machining some hefty heat sinks. just thought i would share.
Reply:Thoes little nickles look sweet, share more if you have them. And thanks for sharing. Good luckGod speed Sent from my Desire HD using Tapatalk 2
GMT+8, 2025-12-27 22:14 , Processed in 0.102283 second(s), 18 queries .
