cleaning aluminum after welding
发表于 2021-8-31 23:13:58 | 显示全部楼层 |阅读模式
What is the best way to clean up aluminum after completing a project before sending it out?  The chemical film is now white and discolored. Using a flapper disc all over doesn't seem to be the way to go
Reply:I would assume if its good enough to clean before the weld, try acetona and a spare SS brush.
Reply:are you talking about removing the frosting from the cleaning action? if so for this i use either 600 grit wet sandpaper then 1500 to finish or scotch-brite then aluminium polishing compoundit all depends on the finish you are after
GMT+8, 2025-12-27 22:23 , Processed in 0.099170 second(s), 18 queries .
