atv winch as hoist
发表于 2021-8-31 23:13:51 | 显示全部楼层 |阅读模式
would an atv winch rated for 3500 lbs pull be able to handle a lifting load under 1000 lbs on a truck crane?     FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:It will lift it but don't depend on the brake to hold the load. All the winch mfgr's stress they are for pulling, not lifting.                                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:you all so need to remember the weight  of the quad. you might need to anchor it down.
Reply:Originally Posted by mla2ofusIt will lift it but don't depend on the brake to hold the load. All the winch mfgr's stress they are for pulling, not lifting.                                                 Mike
Reply:Originally Posted by MondoCheck tne manufacturer's operating instructions to see if it plays out under power - "power out".  If not it is unsafe for lifting.- Mondo
Reply:Search for dynamic vs mechanical braking.  A DC motor in a true hoist will usually have dynamic braking that retards the load from free-fall. Some winches have both types. WARN.com will have some helpful info.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:My buddy broke one in half last year under its own power. Too strong for its own good! Made me wonder tho when he showed it to me. Probably not a good idea, but look into it anyways I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:yea, not only holding/braking strength (regarding the load), but if you ever tear it apart you'd see that they're really flimsy made.  Nothing you'd want to bet on to support the weight they're advertised at, or even 1/2 of it.  It'll work, but eventually it's gonna fail.  It's just a matter of when.  In the best case scenario, nobody's around to get hurt......or say "I told you so" Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:I wouldnt trust it I have used a 2500 pound warn before for over head lifting in a pinch and I had to keep my hand on the button to keep it from slacking off. You might want to install a drum in front with a clicker style lock  like on the hand boat winches. Warn makes a over head winch they are not cheap though. Attached ImagesVantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:They make purpose designed hoists and such. Id get one of those instead of jerryrigging the atv winch. Lifting stuff is not the place you want to go cheap, improvise, or take shortcuts on.Hobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:Originally Posted by weldermikeMy buddy broke one in half last year under its own power. Too strong for its own good!
Reply:Thanks for all the input.I decided to forget the winch because i found a hoist that warn makes called a pullzall rated for 1000 lbs lifting and pulling,comes in 110 volt or battery and i can just hook it on to my crane with its own hook.Also a great comalong,by the way i have no affiliation to warn it just seems like a great idea and works for me and its under 3 bills     FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:I have been using mine on a boom for about two years with no issues, You just have to be smarter than the equipment you are using. (do't get under the load) I also don't lift more than I know it can handle (the crane) Another feature that I really like is I can use it with a snatch block to pull stuff up into the truck via a ramp.
GMT+8, 2025-12-27 22:42 , Processed in 0.126223 second(s), 18 queries .
