made this tonight. did the bend on the handle with a socket and a hammer and propane torch. used oxy propane to heat to twist and to forge the point/ i need a hefty enuf propane burner so i dont have to use oxyfuel. Attached ImagesZach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:nice I like it alot
Reply:I like it but..You don't stab steaks!You use tongs!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI like it but..You don't stab steaks!You use tongs!...zap!
Reply:Never stab a steak!!! What did it ever do to you???
Reply:Cool bending but a BBQ tongs or spatula would seem a better option IMHO...Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:FLIP! Don't stab or poke! Let's the juices out
Reply:He could always use it for hamburgers and hotdogs.
Reply:how do u make a spatula or tongs? still learning on the metal work.Zach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:Spatula would simply be the same as your hook only weld or rivet a flat sheet to the end. Tongs are a bit more involved, but tongs are a traditional tool for forge work and aren't that hard once you get the hang of it. Thin "wire" tongs like for hot dogs are a bit easier to make than traditional forge tongs. Simply buy a store bought set and look at how they are made. The two sides are identical. Just make the 2nd one match your 1st and you are all set.As far as a propane forge, there's a lot of good info on the web that will help you build your own burner. Search "Reil Burner" or home made propane forge, and you will find a bunch of info. I made mine using a stack of fire bricks and had decent results after I got a big enough propane reg. I also made a coal forge that was very simple to make as well..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan |
