6011 VS 6011... Hobart VS Lincoln Comparison (Video)
发表于 2021-8-31 23:13:48 | 显示全部楼层 |阅读模式
Hey y'all!!This is a little test that I put together here recently, I'd known since I first "really" started welding that different brands of electrodes were no doubt different... Ive seen more difference in 6013 electrodes from different brands than I've seen difference from running 6013 to 7014 before, for example.I thought it'd be cool to mess around with, so I bought a box of Lincoln 6011 and another unopened box of Hobart 6011 and did a little redneck testing.I honestly thought they'd be more similar, there was a HUGE difference when running them side-by-side. The Lincoln didnt run nearly as smoothly as the Hobart, but the Hobart produced more "fluid" slag over the puddle, and MUCH more of it. Some things were close, like the ease of removing slag from the finished weld, and some things were different, like the strength. There was a much bigger difference there that I ever thought there would be. I'd always assumed "6011 is 6011... It might run a little differently, but it should be just as strong as any other 6011".Little did I know. lol.Anyway, the video shows more. If y'all like watching this, I'll do it again with some 7014 or 6013 or 7018 or whatever...Enjoy the video, and happy welding everyone  [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Interesting demonstration/comparison, I have been running Hobart 1/8" 6011 lately on DCEP at about 130-135 amps on 1/4" material. But I'm NOT about to try beating it apart.Maybe on your next video like this you could do different amp ratings, too. I feel the higher amps like this will get better penetration and be harder to beat apart. Same rods, different amperage, and different brands and various amperages.
Reply:Get some ESAB Atom Arc 7018 if ya can...  has real good feedback on it.   Ask the pros what their favorite brands are then give some of those a try...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:The real difference for me is when I'm welding out of position. Lincoln Excalibur 7018 1/8 vs. Hobart 7018 1/8. Same heat setting, same welder (Miller XMT 350) running multi pass straight up, there is no comparison. Lincoln has a better, more consistent running rod. I've used both in the same day. (I ran out of Excalibur) I was cursing out Hobart for most of the afternoon because of their junk rod. I run through a fair amount of 7018 1/8, and I'm of the opinion that Lincoln nailed this one. Nick.
Reply:Thanks again Lanse for taking the time to video.Like others, I'd like to see you do a  7018 comparison with Excalibur and Atom Arc.I've ran both and under my limited experience couldn't find a diff., but I didn't "stress test" either **I'd cough up $5 through paypal for supplies**Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:I just purchased 50lbs of Thermadyne Firepower 6011.After purchase I noticed that it's "encho de Mehico" I try not to do that.To add to the comparisons, I'll try to file a report after it's run.
Reply:Love your scientific approach. No blah blah but just do the experiment and show results.Keep going!
Reply:thats a lot of rod under that shelf with no protection from moisture !miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:What Lincoln 6011?  There are Lincoln Fleetweld 180 6011s, Lincoln Fleetweld 35 6011s, and Lincoln Fleetweld 35ls 6011s.  In order of preference I like 35ls, 35, then 180.The Fleetweld 180 is designed to run with the lower OCV of the crackerboxes.
GMT+8, 2025-12-27 22:42 , Processed in 0.085170 second(s), 18 queries .
