Old vs. New, Wood vs. Steel
发表于 2021-8-31 23:13:47 | 显示全部楼层 |阅读模式
Installed some railings today to replace the outdated Newell post and spindles. Homeowner wanted a modern commercial look. The new railings really opened up the room. Attached Images
Reply:That looks snazzy, great job you done there.
Reply:I'd say you pulled it off. I really like those. Just wondering, about how much would something like this run for?Northern Tool MIG/Flux coreWEL-BILT 4 1/2 angle grinderYou gotta start somewhere!
Reply:It looks great.  The only problem I see is rug rats climbing to the top and going over.  Dan
Reply:Very nice! I notice an overlap dealio going on that holds the horozontal pieces, how does that work. Also what material did you use?  3/8 rod? The rail looks like 3/4 by 1 1/2? Thanks!Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:NICE !!!!!!!!!!   Real changes the appearance. More modern for sure.
Reply:Thanks for the compliments guys.dbales: materials cost were about $300.00 labour was whatever you value 40 hours at.DanD78: Yeah it could be a ladder for rugrats, but the kids in this family are teenagers, not a big concern here.Elliot May: The overlap dealio is 1/4" by 2" flatbars welded to the 1/2" roundbar from the back to hide the welds.  First flat bar is easy to do, second one is a little challenging to poke a mig gun into to weld. Top rail is 1" by 2" rectangular tube.-Dan
Reply:Using it a a ladder may not be a concern now, but those teenagers will have rugrats soon enough.......but on that note I really like it. If I had a place ( at home) that needed a railing I would probably copy it.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:The lighting changes in the before and after shots make the flooring look nicer too....... Your railings are great looking...... Much more modern that the before shots......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Did you do any of the welding in place or pre-fab everything elsewhere? Nice job!
Reply:WestcoasterLook at your own photos.The ceiling lamps and doors are incongruous with your rail improvement.What are you going to do to make all-one?OpusLast edited by OPUS FERRO; 11-26-2012 at 01:04 AM.
Reply:Originally Posted by FexalThe lighting changes in the before and after shots make the flooring look nicer too....... Your railings are great looking...... Much more modern that the before shots......
Reply:Looks awesome!-Markhttp://www.facebook.com/Knappmobilewelding
GMT+8, 2025-12-27 22:43 , Processed in 0.080707 second(s), 18 queries .
