New to me rod oven
发表于 2021-8-31 23:13:46 | 显示全部楼层 |阅读模式
I picked up this 350#, Phoenix DryRod oven, off of CL for $150.00. The power cord had some insulation missing in spots and when I went to change it, the inside wiring looked bad so I replace it all. I pick up some high heat wire from the local electrical supply house for going down to the heating elements. Then I decided to make it look like the new Lincoln ovens. I wire wheeled the whole thing, painted it with a coat of high temp primer and then red and black. I've got four fire bricks I have to cut 1/2" off to stand them on their side and to help retain heat instead of opening more than one can of each size 7018."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:And I added a 400*F, cooking oven, thermometer."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Sweet deal!  Nice refurb job too.  Wish I could find myself a deal on one of those been looking for awhile.  Price on a new one is out of the question for me.  Buy it from ya for $200? (Just kidding).
Reply:Keep looking Poptm, the deals are out there. In the middle of the summer I found two of these, in rougher condition, for $50.00 ea. I should have jumped on them, but I thought they would be too big. I really wanted a Keen 200#, but try to find a deal on one of those. So I figured I would bite the bullet and deal with the big one."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:So how long does your new slow cooker take to do ribs? that ought to do a great job making you a nice hot lunch. Looks good there Dean. I got your text the other day. Happy Thanksgiving to you also..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:COOL !    What a difference some time and paint will do. The Lincoln decal is a nice touch.
Reply:editBeutiful Job.  Hellacious deal!  I really like the paint scheme.   If I get something like that,  I'm gonna copy it!  Is there an advantage to a bench oven oven a portable?   I've never had either one.  I hardly ever welded with 7018.   However, as my daughter is learning to weld,  I want her to use 7018, as she is having trouble learning with the 6013 and 6011 I have.  I just called a couple of friends about this and one of them said he knows a shop that has a  Phoenix 300 oven they don't use  for about $150, but it has a busted thermostat.  Easy fix.Last edited by Housedad; 11-25-2012 at 08:05 PM.Victor Oxy weld/cut Setup Meco Midget Torch outfitEverlast 2016 250EX & Power Cool W300Lincoln Power mig 210MP  w/amptrol and Spool GunEverlast Powerarc 200 Hypertherm Powermax 45Bandsaw, Lathe, grinders, press, Bridgeport, etc.
Reply:Originally Posted by DSWSo how long does your new slow cooker take to do ribs? that ought to do a great job making you a nice hot lunch. Looks good there Dean. I got your text the other day. Happy Thanksgiving to you also.
Reply:Housedad -I wouldn't think it would really matter, for practice purposes, if the rods were not kept in an holding oven once the original container was opened.  I would think if you kept them dry and in the house in relatively low humidity and/or in a resealable container and only took a hand full or two outside to practice with at a time (and used them all), that they would be just fine for welding scrap, non-structural stuff and practice for quite some time.  As long as they do not get "too wet" (i.e. absorb too much moisture) they should weld well for practice purposes. That being said, for code work, structural welds, certified welds, etc. that's another matter entirely.  In these instances, you absolutely need to properly store, hold, recondition and/or discard low hydrogen rods as required by the specs.  In many facilities some one will make sure the welder complies if the welder doesn't himself.  If one doesn't the rod will no longer be low hydrogen and will defeat the purpose of using such a rod.  It can result in porosity and weld cracking. If you decide to get a holding oven to teacher her how to properly "hold" low hydrogen rods, please be aware that if she leaves rods exposed too long (according to Lincoln more than 4 hours for the non moisture resistant types and 9 hours for the moisture resistant types) your benchtop holding oven or portable holding oven isn't going to cut it with respect to keeping the rods properly.  If she does that and you want to teach her how to get the rods back to spec you'll have to get a reconditioning oven to get the electrodes to a higher temperature than that which most "holding" ovens are capable of.   They do sell ovens that are both reconditioning and holding ovens.  These however get expensive (and are big).  You can buy, use, practice with, and then discard a lot of unused 7018 rods for the price of such an oven.
Reply:Stick man, Dam nice job looks good man!! Like to save-refurbish stuff myself. Nice find
Reply:I have one just like that but in a little better shape than yours "was" in. I've had it for years and have never turned it on. I really should sell it.
Reply:Originally Posted by powerStick man, Dam nice job looks good man!! Like to save-refurbish stuff myself. Nice find
GMT+8, 2025-12-27 22:43 , Processed in 0.107528 second(s), 18 queries .
