putting AR450 plate in dump box ??? on welding to mild steel of box
发表于 2021-8-31 23:13:43 | 显示全部楼层 |阅读模式
Purchased AR450 steel plate 7.25 feet x 14.0 feet for lining dump box.The present steel in dump box is mild 50,000 steel.How should I proceed in welding the AR450 steel plate to the mild steel?Any comments on what to do?
Reply:How thick is the ar plate
Reply:Depending on the thickness of the plate, you should have no problem with an E7018 and other similar rods.Here is a link with the chemical make up of the steel:http://www.cliftonsteel.com/tensalloy-ar450.htmlI break things for a living...
Reply:AR450 steel is 0.25 thick
Reply:7018 will work fine."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Originally Posted by norite7018 will work fine.
Reply:Originally Posted by burntside bobPurchased AR450 steel plate 7.25 feet x 14.0 feet for lining dump box.The present steel in dump box is mild 50,000 steel.How should I proceed in welding the AR450 steel plate to the mild steel?Any comments on what to do?
Reply:As Hobo stated when I. Didn't have the plate full seated I. Had problems with the material coming free. The plug welds will help alot. Get your dogs, wedges and be prepared to do some hot tacking and it'll all work out.
GMT+8, 2025-12-27 22:42 , Processed in 0.101965 second(s), 18 queries .
