Eutectic OA Torch
发表于 2021-8-31 23:13:38 | 显示全部楼层 |阅读模式
I have an old Eutectic OA cutting torch.  Does anyone know what brand of tips this would be compatible with?  If I'm correct, I should be able to identify what design tip it is just by its physical appearance after tip removal.  Is this correct?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Should be able to find it on this site. http://www.atlweldingsupply.com/Cutting-Tips_c_55.htmlDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Pobably the harris 6290 stuff.  I don't know if they bought stuff from harris and chrome plated it or were a division of harris.  Though I have no way of knowing if they got stuff from other sources.  They have made (marketed?) essentially the harris model 50 and the stuff in the metalizing spray on metal coating suitcase things I have seen are pretty much the 85 model.
Reply:Show us a pic of the tip base. All equipment ID questions should have pics where possible.
Reply:TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:It appears to be a Harris type.  I ordered 2 for propane.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Yup. Harris style.Lots of them available cheap, so you benefit!
GMT+8, 2025-12-27 22:43 , Processed in 0.076854 second(s), 18 queries .
