A friend brought me a relatively high end wood stove with a leg broken off and asked me if I could weld it back on for him. The break is a couple inches where the leg attaches to the stove between the end and where the leg bends down. I am assuming usual procedures for welding cast apply but thought I'd ask just the same on what the best approach would be. The metal is about 3/16" thick.Thanks for your help.Steve in Central TX
Reply:First thing we need is the process you plan on using...Clears up alot right off the bat....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by stevewmA friend brought me a relatively high end wood stove with a leg broken off and asked me if I could weld it back on for him. The break is a couple inches where the leg attaches to the stove between the end and where the leg bends down. I am assuming usual procedures for welding cast apply but thought I'd ask just the same on what the best approach would be. The metal is about 3/16" thick.Thanks for your help.Steve in Central TX
Reply:Originally Posted by Oldiron2 What does everyone here have against SUPERGLUE? .
Reply:Bailing wire and duct tape! Ain't no 'lil heat gonna tear that combo up!Lincoln Power Mig 216Lincoln AC/DC-225/125Miller 625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita Baileigh NRA Life Member
Reply:Originally Posted by zapsterLegs get HOT...Superglue don't like HOT....zap!
Reply:[QUOTE=Oldiron2;1121451]Guess you never had the kind they once used to hold the Space shuttle Tiles on with! You mean the last shuttle to blow up because a piece of styrofoam struck and busted a few "super glued" tiles????Good stuff.Last edited by SuperArc; 05-05-2012 at 04:12 AM.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller 625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita Baileigh NRA Life Member
Reply:Use nickle rods for that job, They cost bout 3 bucks each round here,but its the easiest way to fix that problem without any pre or post heat treatment JMO
Reply:Originally Posted by zapsterFirst thing we need is the process you plan on using...Clears up alot right off the bat....zap! |
