SA 200 Troubleshooting procedure.
发表于 2021-8-31 23:13:33 | 显示全部楼层 |阅读模式
Confused about procedure for basic SA 200 troubleshooting posted by weldmart.My machine is code 6340-A, serial RA599778. Just installed exciter coils by Hybriweld, Morgan City LA.Procedure:1 -Removed brushes, not touching anything.2 – Separated wire as instructed.3 – Using Simpson 260 to read resistance, set at RX10,000, selector on DC+.4 – One lead on right brush holder, the other to each separated wire. No readings whatsoever. Indicator does not flicker.5 – One lead on right brush holder the other to center terminal of rheostat. Reading moves to 0.6 – one lead on each welding output terminals. Reading moves to 0.According to my understanding of Weldmart's instruction, the thing is not supposed to weld but weld it does and a fine job of it.Someone enlighten me, please.Thanks.
Reply:Polarity selector is irrelevant and I would be using the Rx1 scale for testing exciter or shunt coils with your Simpson 260.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-27 22:42 , Processed in 0.104281 second(s), 18 queries .
