hardfacing price question
发表于 2021-8-31 23:13:32 | 显示全部楼层 |阅读模式
whats the going rate for hardfacing buckets (small to medium, mild steel) looking to barter some work and never did out of house hardfacing so never had to price it out.I know there are a lot of variables, but this is for a landscaper with light mixed use equipment, nothing crazy. no special rodhttp://fucdatbirth.blogspot.com/
Reply:I don't own a shop so I am not sure . But hard face wire costs more than regular wire. I bought some a month or so ago and paid about $200 for a 25 pound roll. I got lincoln and really like the way it welds. Good luck with your project.
Reply:no specail rod?So you are going to mostly be building up worn equipment with what ever rod is old or not used often?I would price it the same as any other welding job, he needs it done and you need to pay for consumables, electricity and your time.
Reply:I always try to get them to buy hard face rod because of costs and it gives them a dose of realitySent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:There is a HUGE difference between hard facing and rebuilding a worn surface.Those rods are very costly (for good reason). So you may want to consider it as 'just' another repair, unless the customer insists the use of really hard metal.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Can't you just use 7018??If your doing small build up on small buckets or teeth, 7018 will do just fine.JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Communicate with your customer and find out if they want build up or hard facing. Two very different things, two very different costs...also there are different types of hardfacing rods, too. Personally for light equipment landscaping you're probably just fine with 7018 buildup...Hobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:Great advice all around, i'm gonna use 7018 and price it out for a few hours.http://fucdatbirth.blogspot.com/
GMT+8, 2025-12-27 22:42 , Processed in 0.083357 second(s), 18 queries .
