Hobart Beta-Mig 250... Keeps blowing breaker
发表于 2021-8-31 23:13:31 | 显示全部楼层 |阅读模式
I have 100A service to my shop. Welder on 50A breaker. Doesn't matter what settings on the machine and sometimes it trips the breaker when only feeding wire. Right now I am filling nicks in mower blades with it set on low range voltage tap 5( of 9), wire speed at 5( of10). Anyone have ideas of stuff I can check?ThanksSafety 3rdGump
Reply:Check the electrical wires that run from the breaker to the wall socket if the wire is to small it may overheat and cause a breaker trip or you might want to buy a bigger breaker say a 60 amp.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Thanks Joe. They are 6 gauge and this is not a new set up. I have done a lot of welding on heavier steel with it for the last year or so. Just recently started tripping the breakerSafety 3rdGump
GMT+8, 2025-12-27 22:43 , Processed in 0.108251 second(s), 18 queries .
