Classic 300D help!
发表于 2021-8-31 23:13:25 | 显示全部楼层 |阅读模式
My 300D shuts off and puts it's engine protection light on after I have done about 3 passes on an 8" pipe with 1/8 7018. It has just started to do it. Tomorrow I will try and put more oil in it but on the dip stick it reads in the middle. Anyone else had this problem? The PC board is pretty much brand new. Has around 100 hours on it. Perkins engine. Any help would be great! Thank you
Reply:Could be a defective oil pressure or coolant temperature sender.If you know the oil pressure is good and know that it's not overheating, disconnect each sensor one at a time to see if/which one is triggering the engine protection system to narrow down the cause.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Righto ill give that a try today! ThanksSent from my iPad using Tapatalk
Reply:I have another question on my welder. Classic 300D. It's not the welder that I need help but the volts it puts out. As I have recently moved to Australia I needed Aus outlets while out on site. I had an electrician instal an outlet on it. The max that say is 230v with a 10% fluctuation safe zone which will make it 240 at a safe volts. I tested it and it's coming out with 268v even when I put a load on it(grinder). I am wondering if I can somehow turn the volts down on it? Thanks for the help Sent from my iPhone using Tapatalk
GMT+8, 2025-12-27 22:44 , Processed in 0.101485 second(s), 18 queries .
