Generator cart
发表于 2021-8-31 23:13:22 | 显示全部楼层 |阅读模式
Got a generator, needed a cart. I made one that could be used for other tasks if needed. Sent from my ADR6400L using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:1.5 inch angle, 12 ga steel, 10 in hd wheels. Sent from my ADR6400L using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Sent from my ADR6400L using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Your fab skills are dang good!Nice work..........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Nice, I like the design. Are those wheels from harbor frieght ???  I bought some and they can'tbe beat for the money. The elevated part needs a seat cushion. now you can rest after you start it. You gonna add extension cord holders ?
Reply:Nice job.  Makes me want to sit on it and take a ride.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Nice.The only down side to this I see is storage. You might think about redesigning the handle. A folding design like is used on most lawnmowers  ( simply wait until spring, then nab one off a dead mower when someone tosses one at the beginning of the season) or simply one that you can detach for storage might be a better option. I like to keep my generator under a shelf in the shop so it doesn't take up valuable floor space since I seldom need to use it on a regular basis. Your cart looks like it would be perfect for that except for the handle issue..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice build.  I like the turning wheel.  I been trying to think of a compact cart for my generator.Curious, why you used a solid sheet under the generator?
Reply:I like it.but I can't stop wondering why the garage door doesn't close and seal...There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:1. The garage doors, hmmm guess i never noticed! Maybe so the critters can get out of the cold2. The sheet steel pan for the generator: a. i had it sitting around and.... b. i wanted the cart to be used for moving the generator and holding it when its in use. But i wanted the cart to be available for hauling stuff around the yard too, so it is not a dedicated cart specifically but can be used for anything. The finished product will be painted and might have a place for cords, but if all goes to plan I never have to use the dang thing in the first place!3.  I thought of the handle issue and there is no question you are right there, i may put a hinge mechanism on it so it can be folded down for storage or have the entire handle system be removable with a reciever type collar at the bottom of each member with heavy pin / lynch pin setup like the draw tite trailer recievers. Thanks for the input!Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:I'm sure a PTO pin will work fine as your retainer pins if you do it that way. thats what I'd use at least.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-27 22:43 , Processed in 0.083208 second(s), 18 queries .
