Axle "save" ...
发表于 2021-8-31 23:13:21 | 显示全部楼层 |阅读模式
I got a call from a guy asking me to "finish" welding the brackets on his axle.... Said " he had them all tacked up"..... Ok, so when he drops the axle off....this is what I had to deal with.... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Did you tell him you have to cut it all off and start over.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:After about 10 hours of grinding, cutting, sand blasting and cleaning ...I was finally able to start actually welding... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by TJSDid you tell him you have to cut it all off and start over.
Reply:Continued.... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:I told him...next time he has wants to tack something together to call me first and that I would come and "tack" whatever he needs and then finish welding the parts....Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Good job....
Reply:If those are his "tacks" I wouldn't want to see a complete welding job,LOL!!                                                     MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Nice fix! Did you check how much the axle tube warped? A lot of welding on the backside side it looks like. It would make for a toe-out condition. Not good for a rear axle. If you did how much and what method did you use to straighten?
Reply:I don't have the equipment to measure an axle, but I did tell him that it may need to be checked and straightened...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Lube changed too. See "it only takes two minutes" to do the job...Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by skinny99Nice fix! Did you check how much the axle tube warped? A lot of welding on the backside side it looks like. It would make for a toe-out condition. Not good for a rear axle. If you did how much and what method did you use to straighten?
Reply:DemonSpeeder, what welder did you use for that job?Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by SuperArcDemonSpeeder, what welder did you use for that job?
Reply:Originally Posted by DemonSpeederI got a call from a guy asking me to "finish" welding the brackets on his axle.... Said " he had them all tacked up"..... Ok, so when he drops the axle off....this is what I had to deal with....
Reply:Originally Posted by DemonSpeederContinued....
GMT+8, 2025-12-27 22:44 , Processed in 0.104017 second(s), 18 queries .
