Aluminum sign frames...
发表于 2021-8-31 23:13:15 | 显示全部楼层 |阅读模式
I made these aluminum sign frames for my brother in law... they slide into vertical stands for his photography bis... 1'' x1/8'' wall C-channel, pegs turned from 7/8'' solid.... Used my Square Wave, 150 amps (with peddle), 3/64 4043 filler... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Continued.... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Nice!That's a great looking welding table you have there!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick VNice!That's a great looking welding table you have there!
Reply:smart idea keeping the close ups blurry....
Reply:Originally Posted by vettepickingsmart idea keeping the close ups blurry....
Reply:Originally Posted by tig_21maybe you should think and put your brain to work a little bit before you post something there vette.....Nice little project though, small tubing is hard to weld on aluminum you can't really get into a rhythm i've noticed.....
Reply:Here is a few pics from the Chattanooga Farmers market... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:......Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:.......... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Nice. The design makes more sense now that I see it in use.I like some of his bridge picts you have shown as well. He does nice work. I'm not usually a one for wall art, but if I saw those I'd be tempted to get one. Have you ever had him take any weld picts of you? With his skill with framing images, lighting and perspective, he'd probably turn out some really cool ones..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWNice. The design makes more sense now that I see it in use.I like some of his bridge picts you have shown as well. He does nice work. I'm not usually a one for wall art, but if I saw those I'd be tempted to get one. Have you ever had him take any weld picts of you? With his skill with framing images, lighting and perspective, he'd probably turn out some really cool ones.
Reply:Originally Posted by vettepickingExplain how my brain is not working?? I just think the welds look cold and unsafe for overhead use.  Plus they were blurry, I always take my time and post good pics for everyone to see.
Reply:Those look like perfectly functional welds to me, even though they are blurry.  Suspect you are a better welder than photographer (with a phone).  Thanks for posting the project.
GMT+8, 2025-12-27 22:42 , Processed in 0.112788 second(s), 18 queries .
