Tig Spatter??
发表于 2021-8-31 23:13:13 | 显示全部楼层 |阅读模式
At about the 6:20 mark right when he (edit: quits giving the tour and finally....) lights up on this idler wheel spatter starts flying. He mentions it in his description that it's due to high energy. What is the more likely cause? Sparklers for filler rod maybe? No looks at the 'after spatter' bead tho.Sorry for the long vid, it isn't mine and I'm not even really sure how I stumbled on it.[ame]http://www.youtube.com/watch?v=eOBndOqZjwI[/ame]Last edited by that'll_buff_out; 05-12-2012 at 08:14 AM.How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:that's a lotta fireworks going on. I was wondering how clean he ground that idler down before welding. It's hard to tell.Also, at 6:45 he looks to have the torch in post flow for a really short amount of time???What size machine(HTP?) is he using?
Reply:That's kinda crazy. I've never seen that before from TIG welding. Was he using a stick electrode as filler or something?Brad GeorgeCurrent Equipment:AIRCO Heliwelder IV 300Amp Model - Total Awesomeness!Old 120v Hobart Handler MIGVarious grinders, cutting tools, hammers, clamps, ect..."I'm an amateur welder with lots left to learn..."
Reply:word of the day porosity!don't  be mad cause i can be mad cause you can't!
Reply:Is this another U-Tube post on HOW NOT TO DO A JOB?1.  Wrong welding process.2.  Inadequate prep.3.  Taking bets at 10:1 the repair fails.Wonder if the "author" ever heard of preheating?Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:He never cleaned the wheel. Mistake one.He should be building it up with stick welding process. Mistake 2.Thats a large and heavy wheel. It should be pre heated prior to welding. Mistake 3.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Mistake #2  -  Why should it be only completed with Stick ??
Reply:Did you see the spatter/sparks in the video while he was tig welding? Thats contamination reacting with the weld process.Thats a dirty piece of material. I'm sure the grease/oil and dirt are imbeded in it very good.Tig is not the process to be building this part up with. You need something that can burn through the contaminents.Last edited by snoeproe; 05-12-2012 at 10:16 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:The only time I see that stuff pop off is on mild steel that's not shiny clean.Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:Well he does say "not bad" at the end but never does show us the result now does he. Maybe he pulled a fast one on us and clamped a stick of 6010 in his TIG torch. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-28 00:05 , Processed in 0.211967 second(s), 18 queries .
