Struggling with my 3G cover pass, any tips?
发表于 2021-8-31 23:13:01 | 显示全部楼层 |阅读模式
I'm in a vocational school and have only 2 weeks left to get my 3g. Struggling with my cover pass any tips?
Reply:Whats the problem??Pictures?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Are you turning your heat down? Are you getting undercut or a crack? Porosity? What process?Sent from my iPhone using Tapatalkif you can step across it I can weld it.
Reply:I'm going to guess 3G SMAW.Turn your heat down to 105-115.Watch your puddle. 90 degree rod angle, or a slight push angle (no more than 15 degrees). You will go kind of slow compared to other positions. If you're getting undercut make sure you have a short arc length and you can always oscillate the rod on your way up. Basically a little (very little) wiggle.Pictures and/or more info will help greatly. Especially for other members here who can help you greatly.
Reply:Believe it or not, I found that running vertical up by continually tracing the front edge of the puddle and then cutting back across (think overlapping triangles/semi-circles) works very nicely. Just my .02Sent from my iPhone using TapatalkAspiring Top-Notch WeldorLooking for work/experience in Eastern Massachussetts
GMT+8, 2025-12-28 00:07 , Processed in 0.100264 second(s), 18 queries .
