tubing with square sides not curved available?
发表于 2021-8-31 23:12:56 | 显示全部楼层 |阅读模式
Looking for tubing 3 x 3 x 0.25 inch square that has square edges, all I have found is rounded edges.Is tubing available with square edges?
Reply:everything i'm seeing has rounded edges.might could make your own out of two channels welded together.they make a 3x1.498x0.258  A36 channel.  two of those together would get you 3x3x.25 with square edges.... and you'd get to practice running beads http://www.statesteel.com/SS_structural.pdf  (top of page 3)don't know if that would work for what you need to do .... but that's what i can offer
Reply:Check architectural tubing.   Wagner sell Architectrual tubing,  though not as large as you want.
GMT+8, 2025-12-28 00:29 , Processed in 0.119299 second(s), 18 queries .
