Positioner Stuff..
发表于 2021-8-31 23:12:55 | 显示全部楼层 |阅读模式
Major positioner welding today...First up..70 LB flanges that get the treatment..1 Pass..Machine on kill..1/16" 70S-2 filler..1 pass only..3/32" Red..Note the helper wheels on the bottom..Pic 2..Sometimes we need all the help we can get!Note no burn thru last pic..Before we all get our undies in a bunch there is no liquid pressure going thru these..only SAND.Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Couple of small rollers..Getting down inside was no problem with the 'ol "Bent Tungsten Trick"..Same settings as the flanges and the same filler..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Great work Zap....inspirational!!!!!
Reply:Last but not least....Sprockets.Weld the back side only and make it pretty.Yeah whatever.Still all the same settings..Note the block and aluminum plate on the table..Whatever it takes for a hand/arm rest..DO IT..It makes everything so easy.Well that's done.See Ya!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Top Notch as always bud!  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Hey Rick, take note of the rest that he's using in the sprocket picts.Great work as always there Zap..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice work. Sand? Are those flanges for some kind of auger line in a foundry?
Reply:Nice work Zap. I've never heard of the bent tungsten trick. Can you show a picture of it?Safety 3rdGump
Reply:Originally Posted by forhireNice work. Sand? Are those flanges for some kind of auger line in a foundry?
Reply:Originally Posted by GumpNice work Zap. I've never heard of the bent tungsten trick. Can you show a picture of it?
Reply:Can't help wonder what the f'in gret chuck is in the background? Zap
Reply:Yes sir, those dimes definitely belong there.  Very very nice.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Originally Posted by Shox DrCan't help wonder what the f'in gret chuck is in the background? Zap
Reply:Originally Posted by zapsterHere ya go..http://weldingweb.com/vbb/showthread.php...t=copper+block...zap!
Reply:Very nice welds. In the 2nd pic, where it shows a tack...how many tacks would you normally put in on something like that before you welded it out?Also, once it was all tacked together, would you then weld all the way around? Or would you make some stops and starts to try to spread the heat/distortion?The heat / distortion issue is kicking my butt lately and I'm trying to pick up as many pointers as I can.
Reply:Originally Posted by KelvinVery nice welds. In the 2nd pic, where it shows a tack...how many tacks would you normally put in on something like that before you welded it out?Also, once it was all tacked together, would you then weld all the way around? Or would you make some stops and starts to try to spread the heat/distortion?The heat / distortion issue is kicking my butt lately and I'm trying to pick up as many pointers as I can.
Reply:Interesting. Thank you for the info.
Reply:Excellent work as always mate I'm interested in the positioner, In the UK we call them manipulators, is that something you made yourself with an old lathe chuck ?? its a great idea
Reply:Originally Posted by Gerry1964Excellent work as always mate I'm interested in the positioner, In the UK we call them manipulators, is that something you made yourself with an old lathe chuck ?? its a great idea
GMT+8, 2025-12-28 00:07 , Processed in 0.117003 second(s), 18 queries .
