jacob javits convention ctr. nyc
发表于 2021-8-31 23:12:53 | 显示全部楼层 |阅读模式
before i went to work for the doc i was a structural ironworker. here are some pics of the j. javits center being erected. we built this truss on the ground then hoisted it into position. if you look close in the upper left corner you can see the connector guiding it home. Attached Images
Reply:awesome picture!
Reply:this is the crane and a 60 ft. beam in the background on the trailer. Attached Images
Reply:Looks like a interesting job
Reply:this is a 2" moment plate. i had to weld one of these on each beam to column connection. each one took about  4 hours. every one was ultra sound tested Attached Images
Reply:2" !?!?Ill stick to pipe......Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:i hated decking Attached Images
Reply:pre-heating partial penetration column splices. preheat took a long time especially in the colder weather. every groove weld was ultrasound tested so i used lots of run off tabs. i got extra money for no cutouts. Attached Images
GMT+8, 2025-12-28 00:06 , Processed in 0.114820 second(s), 18 queries .
