Wheel repair
发表于 2021-8-31 23:12:51 | 显示全部楼层 |阅读模式
This is how you repair a rusted out wheel. This is how I do it for the Amish in my area. They get the steel rolled then I help make it fit and weld it on. Don't know what you're missing till you weld on old rusted 100+ year old farm equipment. Attached ImagesTrailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:kudos to you sir
Reply:Originally Posted by shortarc. Don't know what you're missing till you weld on old rusted 100+ year old farm equipment.
Reply:Originally Posted by shortarcThis is how you repair a rusted out wheel. This is how I do it for the Amish in my area. They get the steel rolled then I help make it fit and weld it on. Don't know what you're missing till you weld on old rusted 100+ year old farm equipment.
Reply:Amish don't pay you to grind the rust off first?One weld looks like you may have (6 oclock position), the weld at 9 ocloock position definitely doesn't appear to be ground.Penetration would be better if you ground the it first.
Reply:Originally Posted by drujininAmish don't pay you to grind the rust off first?One weld looks like you may have (6 oclock position), the weld at 9 ocloock position definitely doesn't appear to be ground.Penetration would be better if you ground the it first.
Reply:That third photo brings new meaning to the phrase "steel belted radial". Some friends in Kentucky have Amish neighbors and do some similar things to help them out, too.
Reply:No they don't like for you to use that grinder much, takes more time.Just burn it hot with 7018 and boil the rust out without burning through. It's a balancing act.Some of the folks around here that I work for have folks in Kentucky.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Originally Posted by asdfThat third photo brings new meaning to the phrase "steel belted radial".
GMT+8, 2025-12-28 00:07 , Processed in 0.086205 second(s), 18 queries .
