jig for laying out handcuff hatches
发表于 2021-8-31 23:12:50 | 显示全部楼层 |阅读模式
i just finished a project where i had to build and install handcuff/feeding hatches in 60 cell doors. to keep the hatches at a uniform height i built this jig out of sheet metal. the side and the bottom legs had a 90 deg. bend so all i had to do was fit this to the cell door, make sure it was tight to side and bottom and mark it then drill the corners with the magnetic drill and sawzall the marked lines Attached Images
Reply:just curious but how long do they have to empty the whole cell block while you make these modifications?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Doc, very cool!  Can you give us your "horsepower" used on those fine prison projects?  ie weld process (stick, mig, oxy fuel etc...) and electrode or wire type?  Does the prison supply you with good welding equipment?  Thanks!Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:were very old school here.  99% stick. the rest being 110 mig, brazing or silver soldering. good welding equip? i could order what i needed once or twice a year and i stocked up. right now i'm using welding rods i ordered over 10 years ago. money for equip is very tight.
Reply:dualie: this housing area was closed about a year but not because of the welding. a waste line broke under the cellblock corridor. a squad of guy's came in and chopped a 4'x4' hole in each end  of the floor and tunneled the whole length of the house. all the dirt was piled into the cells so we had no access for that period. our work will take 3 or 4 months
Reply:Did you ever think of trying to escape through that tunnel?Safety 3rdGump
Reply:Sounds like the hard way to do the job to repair the pipe. I've have just saw cut the length of the floor and dug it up and replaced the crete when done. I did enough of that digging for plumbers putting myself thru college. Tunneling opens up a huge can of worms if you have to do it by the book and shore everything. Wouldn't surprise me if MSHA wouldn't apply.I can guarantee I dug up pipes under worse floors and a heck of a lot deeper inside buildings than they had to deal with.  At worst I could see having to drill and epoxy dowels the whole length and tieing in bar in the replaced slab, but that's not really any different than when they do road work..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-28 00:08 , Processed in 0.086395 second(s), 18 queries .
