New hobart
发表于 2021-8-31 23:12:50 | 显示全部楼层 |阅读模式
I just got a hobart handler 187 befor that i had a HF dual mig 151 and the hobart is just amazing the gun the wire speed the 7 heat settings its great. I am using co2 with .030 wire about 10 cfh of co2 i dont realy know what the cfh rate is for the welder but it works on 10 cfh.I want to do the mig like tig with this welder which is slow wire feed and good heat but i dont know if i can do this with co2. I also ordered a tweco auto darkening helmet that i have never used befor eather is anyone can help with adjustment post.
Reply:You can do it with Co2You just need lots of time under the hood manipulating the weld bead.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:wow got a big scare today i hit the duty cycle on my new hobart and everything stopped work. I realy thought i burnt up another welder that would make 4. Well after hit the reset 20 times checking the breaker alot and reading the manual it started working thank god.
Reply:If any one has a handler 187 i would like to know if the fan should turn on when you turn the welder on becouse mine does not.
Reply:The fan should run when the welder is on.  Is the welder under warranty?Miller Dailarc HF 250 Hobart 140
Reply:ya i just got it thursday only 2 days i just hope i dont have to send it back i hope they will send me a fan motor
Reply:I hit the duty cycle on my HH 175, it quit welding but the fan kept running.  After letting it cool with the fan running, it started welding again after about 15 minutes.The fan on my HH 175 runs all the time the switch is in the "on" position.  I'm betting the HH 187 is the same.  Take it back or at the very least, give Hobart a call.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:ya i will car hobart monday when their open
Reply:well i dont have to car lol (call) hobart monday becouse i just void my warranty by fixing my welder. I dont know but they say the a-stock factory reconditioned welder are looked at very well i guess mine wasnt. They left out a bolt that holds the fan inplace so i founf a bolt and fixed my fan now it works fine i should call hobart and ask for some pay.
Reply:Sounds like you need a larger machine . What were the conditions that it blew ??  Maybe the machine is at fault .
Reply:BD1 i think you didnt read i fixed it already but the specs of my welder are 20-185 amp 230 v 50-750 ipm wire speed hobart handler 187. The problem was just the fan not bolted into place.
Reply:Originally Posted by mafiacustomzwell i dont have to car lol (call) hobart monday becouse i just void my warranty by fixing my welder. I dont know but they say the a-stock factory reconditioned welder are looked at very well i guess mine wasnt. They left out a bolt that holds the fan inplace so i founf a bolt and fixed my fan now it works fine i should call hobart and ask for some pay.
Reply:You're right  ! I typed this out but got interrupted and must have sent it after you posted. Glad it was a easy fix.
GMT+8, 2025-12-28 00:07 , Processed in 0.113101 second(s), 18 queries .
