Cracked Frame
发表于 2021-8-31 23:12:47 | 显示全部楼层 |阅读模式
Hello All, A garage called me today and asked if I could weld a cacked frame on a late 90s early 00s Dodge Dakota pickup? I know the lady that drives it and by no way was it abused she uses it to deliver mail and daily driver. I have not seen it yet, just wondering if anyone has ever welded a frame on one of these?? Is it common for cracks in this model? Thanx Dale will post pix when I ck it out
Reply:Do you know where it is cracked?
Reply:Originally Posted by thejonn2524Do you know where it is cracked?
Reply:I would pass on that job Ya gotta spend money to make money!
Reply:Auto frames are one of those jobs:  If you need to ask, than you are not qualified to make the repair.  Period.Buy American, or don't whine when you end up on the bread line.
Reply:Google "ICAR truck frame repair". If you cannot perform a specifically approved repair I'd pass.
Reply:Thanks for the thoughts everyone.
Reply:Frames are sketchy.  9 times out of 10 a crack = bent.  And bent = no good.  They'll cut the frame horns off or unbolt them at the firewall and replace with a straight frame.  I currently have a 1995 Suburban diesel in the driveway with a bad frame.  Its a nightmare.Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:mail delivery is abusive.my carrier wears out a set of brake pads every 6 to 7000 miles.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Frame swaps are not as horrible as they appear. I've worked on several (they are routine for used car lots building good vehicles out of multiple-vehicle auction buys).We rarely fix frames on late-model vehicles. Easier to find something with fire damage to the cab/engine bay and grab the frame off of it. Take lots of digital pics and tear down the organ donor first.
Reply:I didn't abuse my f 150 2000 model either but the frame cracked behind the rear axle and in front of the back spring hanger.  It was due to corrosion due to ice melting stuff on the road which would certianly exist for a mail delivery person.  I didn't see a location but this might be the case.  Has the crack been inspected by now?fran
Reply:Thats hit or miss... If its up front, no-thanks. Out back I might consider it, but not likely in the end.....Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:another ? is the frame heat treatedMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Unless its just an easy bed mount or something non suspension related I would also pass even though it's your friend if it failed and killed someone you would be in court having to prove it wasn't your weld that caused the failure.......I have a Million Dollar coverage an I stay away from car stuff......Not worth the risk.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:all i know of the dodge frames is that they are hydro formed.  they also state they use a high strength steel, no telling what material they use.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Well, it's a Dodge. Doesn't surprise me. Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:The larger 1/2 ton up truck were hydroformed.   the dakotas were just stampedVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-28 00:08 , Processed in 0.081065 second(s), 18 queries .
