Spectrum Thunder
发表于 2021-8-31 23:12:40 | 显示全部楼层 |阅读模式
does anyone know if the spectrum thunder will sever 1/4", in the full line catalog it shows what the 375 will sever . it seems to me it ought to its only another 1/16" it has to go threw? i won't be cutting anything over 1/4", sure would like to know before i screwup and buy the wrong cutter
Reply:I have the Miller Spectrum 300 which will cut 1/4 in steel. It is slow but it does the job. I have cut 4ft x8ft sheets with mine. I am not sure about the (Thunder). I think that would be a smaller machine that has a built in compressor. If it is I would not recommend it for 1/4 in stuff. I would recommend the new Miller 375 which has replaced the 300. That one I think will cut 5/16 or 3/8.Welder- Miller Thunderbolt AC 225-DC 150 Plasma cutter, Miller Spectrum 300O/P torch- Victor 100
GMT+8, 2025-12-28 00:30 , Processed in 0.081607 second(s), 18 queries .
