handcuff ring from scrap
发表于 2021-8-31 23:12:27 | 显示全部楼层 |阅读模式
on occasion an inmate has to be restrained with handcuffs. this picture shows a handcuff ring made out of 1in square tubing some 2x3/8th flat and a couple pieces of 1in flat. all this material was drop off from other jobs. i drilled holes so it can be bolted through the wall or welded to any suitable surface. Attached Images
Reply:Great idea, Who is it that comes up with these ideas, do they just ask you and then you make something up??
Reply:the supervisor of mechanics tells me what he needs then leaves me to design and fabricate it. after it's done he stops by and gives me his input then i install it.
Reply:Originally Posted by docwelderthe supervisor of mechanics tells me what he needs then leaves me to design and fabricate it. after it's done he stops by and gives me his input then i install it.
Reply:in 4 years i'll have 30 so retirement is very close. i'm planning on taking a heli-arc course in a couple months so i can work sitting down in a clean, warm shop of my own.
Reply:Originally Posted by docwelderin 4 years i'll have 30 so retirement is very close. i'm planning on taking a heli-arc course in a couple months so i can work sitting down in a clean, warm shop of my own.
Reply:Originally Posted by Gerry1964Keep up the great work mate, i love reading your posts
Reply:thanks 64 and 89!!
GMT+8, 2025-12-28 00:09 , Processed in 0.090376 second(s), 18 queries .
