Trellis
发表于 2021-8-31 23:12:24 | 显示全部楼层 |阅读模式
I had to build a trellis for one of the garden designers that I do work for. This one had to go around the corner of a house and the two sections were different sizes. I've built lots of trellises through the years and it wasn't a problem but I wanted to do a little different flower on top. I remembered Travis Baker's thread a week or so back and thought his twisted metal key chain would make a nice bloom as this trellis looked kind of like a yucca. Here's some pictures. I probably didn't do as good a job as he did because I did it with weldor methods and not a forge, but it came out all right. Attached Images
Reply:Oh I almost forgot, thanks Travis for posting how to do the twist.
Reply:Hey good job!  I like it, its different than mine but very similar at the same time.  Im taking a stab you did a slit in each side of the metal then cut slits in the sections then twisted with oxy fuel?
Reply:Yes, I ground a groove in all four sides and then made cuts at the corners and heated it with a torch and turned it with a crescent wrench. I think it made a great yucca type bloom. Thanks again Travis for posting about it.
Reply:oh your very welcome Im glad I helped someone get a new idea on something
GMT+8, 2025-12-28 00:29 , Processed in 0.433025 second(s), 18 queries .
