dozer blade rebuild and extension
发表于 2021-8-31 23:12:23 | 显示全部楼层 |阅读模式
a d 11 blade that we extended 3 feet each side re lined with hard plate.some before and during pictures. One of the new shop dog ... Attached Images
Reply:more pics.late night work and the finished project.....not me in the photo Attached Images
Reply:Nice trying to show everyone up running to Stingers at once.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Nice job. That is some serious Heavy Metal there!!!! Thanks for sharing.
Reply:If we were in Poland they would say cool  shltski! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Lazy @$$ dog. He should be welding.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Good showLast edited by Insaneride; 12-09-2012 at 09:06 PM.Reason: nice
Reply:Shop dog, guarding that plate by golly. Good dog. That's one plate that won't get stolen."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:specopswelderYour third pic looks like 'Okie-Tig' on a pad-eye; what is actually happening in the photo?Is the Tri-Braze AR 300, 400, or 500?Were the 3 ft. extensions all Tri-Brase, or on mild/T-1 structural backing?It's obvious in your photos that the sections were brake-curved. When delivered [raw metal], there should have been evident, and big, 'ink-marker' arrows denoting the grain of the AR.If visible, did the arrows run lengthwise or crosswise to the break-lines?What was your: filler wire, gauge, and did you 'hog it in', or was there a strict welding procedure?I haven't worked heavy equipment since '92, a lot has changed in welding applications since then; of which I'm unaware.My interest is tiny compared to yours, but the materials are the same, or close to it.I'm welding 3/16 AR 400.  My problem is the welds are structural [loaded],and not static, as in cladding.Any help would be welcome.Opus
Reply:Somebody must have had a 10 yard load of gravel to spread?  Cool project!
Reply:very nice pics! what were you feeding into the arc? i never saw that be4.
Reply:Originally Posted by jimmyjeeperSomebody must have had a 10 yard load of gravel to spread?  Cool project!
Reply:Looks like you had a lot of fun working with it!  Great job.
Reply:Very cool pics but I must ask why were you feeding another stick into your arc? Ive heard of that before, but never seen it. I thought it was a joke or a ghetto-rigged way to help incase you screw up your fit and have a big gap."If you ain't making mistakes, it means you aren't learning anything."
Reply:Originally Posted by SandyShop dog, guarding that plate by golly. Good dog. That's one plate that won't get stolen.
Reply:Awesome!!! I wish I could go back to working on heavy equipment.Chris
Reply:Originally Posted by FarmerJoeVery cool pics but I must ask why were you feeding another stick into your arc? Ive heard of that before, but never seen it. I thought it was a joke or a ghetto-rigged way to help incase you screw up your fit and have a big gap.
Reply:If you are running wire from the suitcases which wire are you using?What are your day time temps in New Mexico?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:opus. Thanks for the interest .I will try to share my little knowledge on ar plate.  It is ar 500. The plate was sent formed to us by another company that specializes in wear products. The graining you ask about runs across the brake lines.There is less chance of the plate de laminating. Very similar to trying to brake flat bar length ways. it will split because of the long grain structure. it can be done but it has to be higher quality steel......nother story.The welding is all done to a procedure. We use several types of wire or rod depending on the application. this was welded with lincoln 71 a85 1/16 diameter .most rods or wire needs to have a diffusible hydrogen of less than 8 mls of hydrogen per 100 grams of weld metal. 7018 h4r is a perfect choice. pre heat to about 350 and weld the plates down. We also use ss 309 . It holds very well in high stress areas. for your application I would use a dual shield wire. Not solid wire it is very brittle when welded on ar plate. or 7018.The pic of two rods is a pad eye being welded on both sides at one time of two separate machines.
Reply:that's just awesome! Nice work, buddy!
Reply:kolot  the temps during the day now are about 60 or so. had a few down around 40. In the summer the high stays arounf 100 to 110.
Reply:Mick we have a nice shop but cant get the work to it. So My crew has been working in the dirt for the past 16 months. The building in the back ground doesnt have power or a roof its a cheap spot of dirt t work on.....mostly a large wind break. We have a three sided 40' x 30' that we push over some stuff. it is all outside. off engine driven welders and air comps. could basically do all the work in a park if had to
Reply:Originally Posted by Letzgoracin301Someone said it i think he's running a stinger in each hand. Sent from my MB886 using Tapatalk 2
Reply:Looks like you missed a couple of bolts on the right side cutting edge.Nice job though!miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
GMT+8, 2025-12-28 00:31 , Processed in 0.079206 second(s), 18 queries .
