Rolling Cart/Stand Brakes
发表于 2021-8-31 23:12:21 | 显示全部楼层 |阅读模式
I'm fairly new to welding and this forum, so forgive me if this idea has already been shared.  I built a stand for a workbench style drill press and wanted a way to easily keep it from rolling around on it's casters when in use.  I'm not a fan of the basic locking casters.  (I tacked the rear casters so they don't swivel)  I looked around my shop and found the parts that I used in this simple project.  The main part that I used is a Carr-Lane plunger style toggle clamp, similar to this one http://www.thetoggleclampstore.com/36202.html .  The rubber feet were salvaged from a Maytag washing machine.  A bit of 1/2" rod, and some aluminum angle and channel are items that should be evident in the photos.    I stood in the corner of the stand and one of the brakes easily lifted the stand, drill press and my 200 lbs.Unit in the down position, which lifts the caster about 1/8"4" aluminum channelSimple angle iron jig to hold the rods parallel Leg from Maytag washer (before I cut the threaded part off, rubber is removable for welding)JackFort Loramie, OhioMilermatic Autoset 180
Reply:That's slick, I like it.  You ought to name that little rig R2-Drill2"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Very clever. me likes!
Reply:That looks nice!! Good idea.
Reply:very nice like the idealJobSmart MIG125Lincoln AC225-SLincoln Pro-Mig 175Dewalt GrindersRidgid ChopsawIR Garage Mate CompressorAny thing worth doing, is worth doing right.
GMT+8, 2025-12-28 00:30 , Processed in 0.086969 second(s), 18 queries .
