Today...... I did Rebeca........
发表于 2021-8-31 23:11:54 | 显示全部楼层 |阅读模式
Another in a series of name plaques for a co-worker....... I get to make them as I  please....... $40 each is what I quoted........ I have 11 to do...... 3 down so far.......Front is 1/4" Aluminum with C channel as the base.....I spent 6 hours today with a plasma and the Dremmel......  5 minutes of welding........ ($4 / hour plus material = $40..... HA!!!!) Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:A few more pics...... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:looks cool dude.Good job.Are you using a plasma to cut out the writing, or doing the old drill & file?I've done one or two things around here for the Mrs with our initials, and its a fair amount of work drilling and filing.
Reply:Looks alright for 40$. I would have used something other than those screws though. Counter sunk would look nice or standard bolts. If nothing else I'd turn the screw slots so they all line up. Just my thoughts.
Reply:Originally Posted by StrangedexLooks alright for 40$. I would have used something other than those screws though. Counter sunk would look nice or standard bolts. If nothing else I'd turn the screw slots so they all line up. Just my thoughts.
Reply:Originally Posted by stiffmanlooks cool dude.Good job.Are you using a plasma to cut out the writing, or doing the old drill & file?I've done one or two things around here for the Mrs with our initials, and its a fair amount of work drilling and filing.
Reply:Are you sure that's how she spells her name?  've only known a few, but they always spelled their name REBECCA. It looks great. I hope it's right.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:I double checked, and then checked again.......  and then checked the email.... then checked one more time......I spelled it the way I was told........I think it's unique..... but who am I to judge.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:And.... I just checked.... again (it's too late.... but I just had to check.... again)....Here is the email my co-worker sent me with the names....Names: Boys: Austin, Ethan, Jeff, Tyler & Nito Girls: Ashley, Alyssa, Rebeca, & Martha  Last one dont know if girl/boy yet Thanks
Reply:Fex 6 hours is a long time but I'm assuming you enjoy it. If you like you can send me the material and I'll cnc cut it for free and send it back to you to save you some time
Reply:Maybe you should be chargin' by the letter.Some people are gettin' a better deal than others if you know what i mean. Will also equate into a little extra $$.
Reply:Originally Posted by Voodoo504Fex 6 hours is a long time but I'm assuming you enjoy it. If you like you can send me the material and I'll cnc cut it for free and send it back to you to save you some time
Reply:No doubt!PM sent.....Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Now that's cool to help someone out like that.Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:You should also look into guys that do laser cutting, there's a company that I deal with that runs machines 24/7 and at times I can get the piece laser cut for the same price or cheaper than I can even by material for it.
Reply:Looks good Fexal. Good on ya Voodoo for helping a guy out like that.  That being said, if these are for children, I think the hand cut letters add a bit of charm to them. As for attaching the plate to the channel. You could use a 2 part epoxy and then you could box the ends of the channel off. And do away with any fasteners. Here is some I have used before and it works GREAT. http://www.azautobodysupply.com/12fuezsesese.htmlKeep in mind that the big tube requires the gun and mixing tips. But I am sure I have seen it in a smaller tube that does not.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Originally Posted by dj55bYou should also look into guys that do laser cutting, there's a company that I deal with that runs machines 24/7 and at times I can get the piece laser cut for the same price or cheaper than I can even by material for it.
Reply:Nice ! What, NO CLOCK ????????????? What about a light for night time viewing ? You could drill a couple 5/16'' holes for those small american flags too .
Reply:Originally Posted by BD1Nice ! What, NO CLOCK ????????????? What about a light for night time viewing ? You could drill a couple 5/16'' holes for those small american flags too .
Reply:This would be a cool application for some little pieces of that explosion welded Aluminum to steel transition material.You didn't build that.'85 Miller AEAD-200LE
Reply:Um, can we see a pic of Rebeca?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:That's really cool. Voodoo, I may be sending you a pm shortly.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Looks nice!Now I'd personally go to her and say something like, "You know, this looks fantastic but for an extra $30 I'll install a light."It wouldn't be hard at all to throw a light in it, and run it off a 110V with one of those in-line switches. (or whatever they're called).
Reply:Damn man $4/hr... Aint nobody got time fo dat
Reply:Originally Posted by SweetBrownDamn man $4/hr... Aint nobody got time fo datOriginally Posted by GambleApparently they don't have time for school either....
Reply:Nice voo doo! Good of you!  Fex, mite consider flush rivets just fir fun !Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Originally Posted by mfldmikeLooks nice!Now I'd personally go to her and say something like, "You know, this looks fantastic but for an extra $30 I'll install a light."
GMT+8, 2025-12-28 00:29 , Processed in 0.468871 second(s), 18 queries .
