welding brass to stainless steel
发表于 2021-8-31 23:11:46 | 显示全部楼层 |阅读模式
What is the best way to connect brass to stainless? It is for water piping.
Reply:compression fittings
Reply:Pro Press with stainless couplingsDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:It is kind of a custom application that a customer wants. He has some goofy valves that he wants us to use and they need to be hooked to a stainless header. They are a sweat valve that is made to have 7/8 copper soldiered into them but he wants no copper. It is going into a 1 1/2 sch 40 ss piece of pipe and it is in a really tight spot. If I could use copper I would soldier the copper into the valve and tig the copper to the header with a2 bronze. I was thinking sliding the end of the valve just inside the header and silver soldiering it, just didn't know if there was a better way.
Reply:+1 for Pro Press.
GMT+8, 2025-12-28 00:29 , Processed in 0.076068 second(s), 18 queries .
