Basic Argon fittings question
发表于 2021-8-31 23:11:45 | 显示全部楼层 |阅读模式
Is it ok to use a regular air hose couplers on my Argon regulator and the back of my welder?I want to use air hoses to run gas to my welder, so I can leave my large Argon tank secured in my shed while I weld in my driveway. I wouldn't think twice about it but when I removed the barbed hose fitting on my regulator I noticed the opening for the gas was a very small hole. I'm wondering if this is needed to regulate flow or if I can just thread on a normal air hose coupler in it's place. Thanks.Last edited by slagmatic; 06-05-2012 at 06:49 PM.
Reply:I've used them, and we set up more than forty MIG and TIG stations using (quality) pneumatic fittings.I also use one such setup at home to leak-check acetylene torches with argon or 75/25 since it's handy.I don't remove the regulator fitting, but instead use a Western adapter to go to 1/4" NPT and screw that into the back of a female thread in an air chuck. I can take that adapter anywhere."Western Enterprises AW-427 Adaptor" is what I use. They are cheap. Attached Images
Reply:Originally Posted by slagmaticIs it ok to use a regular air hose couplers on my Argon regulator and the back of my welder?Thanks.
Reply:I use regular air hose couplers on my set up for getting in and out of my gas mixer..(Modified)..6 years now and they do not leak at allIf they handle 120 PSI air they will handle 12-15 CFM all decade....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI use regular air hose couplers on my set up for getting in and out of my gas mixer..(Modified)..6 years now and they do not leak at allIf they handle 120 PSI air they will handle 12-15 CFM all decade....zap!
Reply:Originally Posted by dave powelsonDo you ever soap check the fittings?
Reply:I used them as well.  I don't have the experience tees guys do, but I had no problems and no leaks.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-28 00:29 , Processed in 0.111037 second(s), 18 queries .
