My First Welds (flame away)
发表于 2021-8-31 23:11:43 | 显示全部楼层 |阅读模式
Flame Away! I need the input.Had electrician over today finally to run conduit and install 230 service to the garage. So I dinked around for a little bit after with the welder. First time welding.My first two beads ever#1 looks like i smeared bubblegum in it.[img][/img]#2 looks better I think but I am getting a little, porosity, I think is the proper term to call it?
Reply:The pics were to big but it wouldnt let me edit the post.heres smaller ones
Reply:Mate, if they're you first welds ever then you're doing pretty well. Yes that is porosity - try and aim for a steady travel speed and keep a short arc length. Porosity often comes from your arc flaring out too much when the rod is too far away. Fillet welds are pretty tricky to master so this is a good effort. Cheers - Mick
Reply:Post the maching, amperage, type and size of rod etc and you will get better feedbackTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:If those are your first welds ever, well you are doing great!   it seems rare that new posters here do as well.   For welding heavy metal, it's a good start.   Not perfect of course, but a good start.Ken
GMT+8, 2025-12-28 00:29 , Processed in 0.099256 second(s), 18 queries .
