weld fixtur
发表于 2021-8-31 23:11:33 | 显示全部楼层 |阅读模式
I just happened to have this picture available and thought I would share it with you guysThis is a Jet Line seam welder. Actually it’s a clamp you add the welding machine of your choice. We use it manufacturing round pipe. Cut--- Roll—Clamp---Weld--Sell--. Attached Images
Reply:Does this use a MIG process to do the welding, or a rolling resistance weld?Appreciation Gains You Recognition-
Reply:set up for Tig with a cold wire feeder
GMT+8, 2025-12-28 00:57 , Processed in 0.639653 second(s), 18 queries .
