#2 hossfeld bender help
发表于 2021-8-31 23:11:33 | 显示全部楼层 |阅读模式
Hi everyoneI'm a new member, this is my second post. I would like to get a few dimensions from someone that has a hossfeld #2 bender with the hydraulic attachment. The two parts I need help with are 49243  (h34) main frame and 49250 (h38) cylinder plates. The h34 main frame part is a 3/4" steel plate 6" wide by ?" with about four holes. I need the length of this part and diameter and placement of the holes. The other part h38 cylinder I need all dimensions and four hole diameters and placement. I bought this bender at auction and didn't get all the parts. The shipping alone from Hossfeld would cost more that it would cost me to make these part. Thanks in advance for any and all help.Andy
Reply:Andy, Just returned from a bout with the doctor's....so it may be a little bit of time before I can get down to the shop to check. Why don't you contact me offline and I'll see what I can scrounge up for you.
Reply:Andy, Received your note, but haven't received any further information from you after replying to the address you gave. The wife says she feels like driving me down to the shop today...so if you can give me a description of the second part you need spec'ed I'll round up the measurements for you. I think the second piece might be the attachment from the hyd. cylinder to the handle, but not sure.
GMT+8, 2025-12-28 00:57 , Processed in 0.264319 second(s), 18 queries .
