weldanpower 225 armature to slip ring wireing
发表于 2021-8-31 23:11:29 | 显示全部楼层 |阅读模式
i loaned Lincoln 225 weldanpower to neighbor for some reason he was going to clean slip rings. He pulled some of wires out of slip rings with paint paddle and sandpaper. It still has gen voltage ,but will not weld. I guess exciter wire  loose.  Where does it attach to armature and does it connect to ring close to motor
Reply:If it still generates proper auxiliary power there's nothing wrong with the slip rings-to-rotor windings wiring.  You need to look elsewhere for no weld output such as failed output rectifier diodes, weld output coarse amperage selector, weld output stator/reactor windings, etc.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks it sure looks rough now. It was fine few days ago. Looked like small wire size of say #25 wire was loose
Reply:I have 12 volts to brush don t think it is getting to armature
Reply:I would sooner think the exciter output circuit is open (blown fuse or failed bridge rectifier) as those are more common.  If you're only getting 12VDC (battery flashing voltage) to the brushes, you shouldn't be getting full auxiliary power voltage at the AC receptacle(s).Got your unit's code# located on the faceplate?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:code # 8927 I have full 110v and 220v  .will check tomorrow .He sure made mess of insulation on wires from armature to slip rings.
Reply:Here's the manual for your unit based on the code# provided http://www.lincolnelectric.com/asset...oln3/im308.pdfHowever, things don't add up.  If you're getting full voltage at the auxiliary outlets you should be getting at least 80VDC at the brushesMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I will get deeper into it tomorrow. the reason I asked about slip ring wireing he made mess of that area. he thought it was dust and dirt.i do have gen power . no arc at all. thought maybe pulled exciter wire loose. he also cleaned wireing print .when I get this one enlarged.maybe ican make sence of all this. Sure has been a trouble free machine till now.Thanks for the help. Sure I ll need a lot more.
Reply:ok some butcher string, cloth tape and epoxy got that mess fixed . Still no welding power will start on that maybe tonight. Don t see anything smoked ,said was welding fine , stopped for lunch ,would not weld. hope nothing bad.
Reply:It s fixed thanks to Duane .
GMT+8, 2025-12-28 02:13 , Processed in 0.096032 second(s), 18 queries .
