Copper Welding Spoon Question
发表于 2021-8-31 23:11:23 | 显示全部楼层 |阅读模式
This may be the dumb question of the week...  ....so,Does the spoon need to be cleaned to be most efficient, or does the smudging and discoloration have no effect on its purpose?  If it does need to be cleaned, what is the best method?  btw-this is the very exclusive and expensive $9 HF tool, but I would like it to work as designed.ThanksTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Discoloration should have no effect. That's like using an old shovel that's dirty....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Dont clean it. It will do the same job and get less "sticky" as you use it.
Reply:I've been using the same piece of  smashed and flattened copper pipe as a spoon.  Never cleaned it yet.
GMT+8, 2025-12-28 04:05 , Processed in 0.097329 second(s), 18 queries .
