Sourcing flat angle braces?
发表于 2021-8-31 23:11:20 | 显示全部楼层 |阅读模式
I'm looking for a good source on the above picture. Looking for all sorts of dimensions. I wouldn't mind if it didn't have any holes either and I could put those in. It seems like such a simple product but I can't find anything on it except the flat angle braces sold at home depot, etc, and I don't really like those ones because they're too narrow. The sizes I'm really looking for are 6"x6", 5x5, 4x4, and 3x3, all 1-1/2" wide x 11ga thick. I don't care about finish either. Any ideas or should I be looking to have someone make these?John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:How many do you need? If I needed a quantity, I'd simply look at having someone with a CNC plasma cut what I needed. Something like that would nest really well so you'd get very little waste..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:A porta-band saw and a drill press and you can make them any size you need as you need them, or make up a whole bunch at one time for later use.
Reply:Simpson Strong-Tie.   They make a much larger selection of the same products you posted and sell them outside of just Home Depot.  Home Depot only carries a small percentage of Simpson's metal building materials.   I know first hand because they are a customer of mine.   I've seen all sorts of metal braces, brackets and "whatnots" they make, yet Home Depot does not carry.   You might try contacting them directly.  Http://www.strongtie.com.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2025-12-28 02:13 , Processed in 0.069880 second(s), 18 queries .
