Shop press Brake
发表于 2021-8-31 23:11:17 | 显示全部楼层 |阅读模式
Made this today out of some stuff i had laying around the shop...works good on the HF 20 ton press with the air/over jack. Not i just need some paint and its good to go!Tested it out with 1/4" x 2" plate stock.[ame]http://www.youtube.com/watch?v=n_B6KH6wGfE[/ame]Let me know what you think or if i should do anything different? Thanks guysLincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Also has any one made a foot pedal for this...or have used this HF pedal??? I just think it would be nice to just have a foor pedal and be hands free.http://www.harborfreight.com/10000-p...ump-98318.htmlLincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Looks good. I like the open clearance.
Reply:Nice press.A foot pedal would be helpful.  I don't think it is as necessary for the short width you will brake.  However, it is nice to have two hands free.    I have  a foot pedal on 39" press brake.  It is really helpful when trying to line up long wide sheets. You will need a pressure gauge too.  Can you get 90 degrees?
Reply:looks damn good!
Reply:Originally Posted by tapwelderNice press.A foot pedal would be helpful.  I don't think it is as necessary for the short width you will brake.  However, it is nice to have two hands free.    I have  a foot pedal on 39" press brake.  It is really helpful when trying to line up long wide sheets. You will need a pressure gauge too.  Can you get 90 degrees?
Reply:Lincoln SA 200 Lincoln Idealarc 300/300 TIG
GMT+8, 2025-12-28 04:05 , Processed in 0.220840 second(s), 18 queries .
