Homemade square tube bender
发表于 2021-8-31 23:11:14 | 显示全部楼层 |阅读模式
The other night I was in the shop and needed a 90 bent out of a piece of 1" square tubing.  After a little head scratching and rummaging through my junk piles, this is what I come up with.  It worked well enough for my application , at least until I get hossfeld built.  LolMiller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:Can you make the pics smaller? I can only see the pic on the left. Also, what guage is the square tube you are bending?
Reply:Looks good, at least what we can see...
Reply:I don't see a bender..Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Raider does this help?Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:how did you grab hold of the tubing?...Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:I'm guessing here.Did you clamp the sqaure stock to the flat stock and heat it up and just pull?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Doesn't look like he heated it, prob. just used a long cheater bar to bend it around the round piece.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:It was just by hand.  I bent a few of them, after the piece was shorter than 2' long, I used a piece of 1 1/2" blk iron pipe for leverage.Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
GMT+8, 2025-12-28 04:06 , Processed in 0.082082 second(s), 18 queries .
