any do structural steel work?
发表于 2021-8-31 23:11:13 | 显示全部楼层 |阅读模式
might have a job in db,fl for structural steel work, but need to learn blueprint reading. anyone got any pionters or what im up against.If the conversation isn’t money, then I’ll see you later.
Reply:Better start looking weld symbols etc.... they can be pretty confusing...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:db, fl? wheres that? my uncle owns a shop in palm beach. worked there alittle over a year. shop and erectingMiller ab/p 330Hobart champ 16Miller 140Lincoln Power Mig 255Lincoln SA-250
Reply:Purchase "Printreading for Welders" by Thomas Proctor & Jonathan Gosse. Its expensive (its a text book), but is comprehensive.
Reply:Go to the Hobart School of Welding in Troy, OH. You can take individual classes there. I'm in a comprehensive program now that lasts for 9 months, and we took a two week class in blueprints, 8 hours a day, 5 days a week. It was a lot of information to cram, but I honestly feel pretty good with my blueprint reading skills now. Highly recommended.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:DB is Daytona/Dania beach?  If you are new to print reading keep a symbol chart with you, it will help alot.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:daytona beach,fl ok ill look into that text book thank you and cant really leave for school yet things are hard when being on your own.If the conversation isn’t money, then I’ll see you later.
Reply:Learning the symbols, arrows, and section views will go a long way in helping you.  For me it was easier to sit there with a print and actually looking at the beam.  Lots of trial and error; not to mention coping the wrong beam flange!  It took me about two weeks to get where I was comfortable fitting beams.  The company I worked for did a good job of letting me learn, and also keeping up with the beams they sent to my horses.  They gradually gave me more difficult beams and tubes as I got better.  There is also a technique to fitting steel.  Some people lay our their beams as they go, but I always laid out my beams from start to finish.  I marked what part went where and only pulled my tape once.  It was easier for me to get in a rhythm that way.
GMT+8, 2025-12-28 02:13 , Processed in 0.191186 second(s), 18 queries .
