查看: 13|回复: 0
chainsaw sharpener
发表于 2021-8-31 23:10:55 | 显示全部楼层 |阅读模式
I need to buya good chainsaw sharpener.  I would like to get one with a 4 inch disk instead of the little 1/4 inch round spinning tip.  I got about 12 chains I need to sharpen for my 029 Farm Boss.
Reply:I am not sure how good they are but harbor freight sells one for a pretty reasonable price.DavidClarke 180 EN.030 wire and C25Oxy/Propane cutting torch
Reply:These guys have given me good service perhaps one of their chain grinders will suit your needs.Baileys"after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:if you buy an 0regon you will never have to buy another.
Reply:dullknife,Were do I buy one?
Reply:Planet X,How do I get ahold of Baileys?
Reply:Originally posted by Sticky Planet X,How do I get ahold of Baileys?
Reply:Chain grinders MUST be bidirectional and have an 8" wheel to be worth a dam.They also spend you a lot of money on new chains if you get too ambitious grinding chains instead of learning to file one.There are plenty of links from www.arboristsite.com for saw equipment, and you might even find one for sale over there.Oregon is about the best sharpener around, and Oregonchain has a damn good web site with plenty of information on filing and grindsing chains.Appreciation Gains You Recognition-
Reply:Chainsaw sharpening is pretty much a lost cause out here in the final frontier on account of the dirt & sand in the wood, especially if you're sawing limbs that have been on the ground for very long.  It eats  into all parts of the chains & causes so much stretching that I have to throw most of them away well before the blades are used up.  I can get them ground at Jan's Parts & Things for $4 each;  she hands about half of the ones I take her back to me & says, "you don't really want to ruin your sprocketts, do you?"  So, I can ordinarily figure on one re-sharpening per chain & having to buy 2 or 3 new ones per season since I only  burn 2 or 3 cords per winter on account of the short, mild winters we have.  At that rate, it would take ten years or so to justify the cost of a good grinder.
Reply:Cutter,My biggest challenge is not keeping the chains sharp, it is finding wood to cut out here!LOL
Reply:Originally posted by Bolt Cutter,My biggest challenge is not keeping the chains sharp, it is finding wood to cut out here!LOL
Reply:There is excellent information on chain filing on the OregonChain web site.I ran chain saws for a good 50 years before I ever had one ground, starting with a miserable sumbich of a saw that had a rotating carburator on the back so you could run the saw sideways.Appreciation Gains You Recognition-
Reply:Franz, with a saw like that, you'd best shut the engine off and find a partner to haul the saw back and forth.  Might have to use vise grips to keep the chain still while doing this.
Reply:if you guys need any support from oregon check this out >>Oregon Factory Sponsered Forum@ LawnsiteStangnetShop Full Of Stuff. Joey
Reply:I cut a lot of fire wood and I NEVER have my chains machine sharpened. Learn to us a file, It is easy and only takes a couple minutes to touch up. I touch up every hour or less. it isn't hard at all. Just buy and use sharp files. watch the angles, and do it often. Makes sawing alot easier.leaddog
Reply:LeaddogI just tried that on the blade on my saw and I havn't sawed with it yet.    I have about 10 dull blades.  The proes seem to only use a file.
Reply:My Dad is a woodcutter from way back,,, just a file like leaddog says.  Rocket science it aint.  One or 2 strokes to keep it sharp.  There is a simple file guide to keep an eye on the angles and a guage to file the rakers down too.  A saw store will have the stuff.Last edited by Sberry; 03-12-2004 at 01:09 AM.www.urkafarms.com
Reply:Its a good thing to have a Dad who's hobby is wood cutting.  I fill about 60 of these boxes every year,,, I didnt have to saw a single piece,,, ha Attached Images
Reply:If you take your raker's down too far you will know it. The saw will try to pull you into the cut- if your saw has enough cubic inches just hang on they will wear down with enough cutting. As far as using your round file, just get some oregon chain with the 'cheater' line, keep the file parallel with the line on top of the tooth and drop the backend end down a bit to what ever angle the type of chain you have specs- 3-7degrees or so. Most people will spend too much time getting the gullet pretty would suggest putting more upward pressure on the file.The top of the tooth is what does most of the cutting- at least till you sharpen a few."after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:Aw geez X yer givin out all the secret information.  Next yer gonna go and tell people you downset the raker different for hardwood than you do for soft wood.  Good thing you didn't mention filing out of the tooth rather than into it.What the hell is a cheater line, when did that come out?  I only been filin chains for 50 years and I never saw a cheater line.  I have watched a couple guys who knew more about filin chains than I did "sharpen" em with tapered round files though.Appreciation Gains You Recognition-
Reply:Originally posted by Franz Aw geez X yer givin out all the secret information.  Next yer gonna go and tell people you downset the raker different for hardwood than you do for soft wood.  Good thing you didn't mention filing out of the tooth rather than into it.What the hell is a cheater line, when did that come out?  I only been filin chains for 50 years and I never saw a cheater line.  I have watched a couple guys who knew more about filin chains than I did "sharpen" em with tapered round files though.
Reply:Kind of like when some as$ asks ya why yer draggin a chain along the ground, there's nothing like the look on their face when you tell em it's easier than pushin a chain.I'm wonderin if Oregon is putting that line on the chain so the stupids workin at the sharpening machine don't grind the cutter past the line.  I've seen chains where they grind em back to nubs, cause they are too dumb to know how dangerous that is.Appreciation Gains You Recognition-
Reply:I cut timber for a living.Skip chain is slow until you get up to a 4 foot bar lenght.Learn to file a chain and save the money on a grinder.
GMT+8, 2025-12-28 04:05 , Processed in 0.096766 second(s), 18 queries .
