5x6 jet swivel head for 500 bucks?
发表于 2021-8-31 23:10:50 | 显示全部楼层 |阅读模式
just was offered a jet swivel head bandsaw for five hundred buck,looks in used but good shape, anyone use these often, howdya likem?face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Yes. Daily, for 10 yrs. Paid 500 for mine new.  I did several tweeks to get accurate cuts.  (shim vise, grind the guide assembly, and grind guide adjusting arms) Put a new motor on last yr. The jet motor finally went out after 10yrs.  The jet motor is over rated, the new motor makes the saw run and cut better than ever, literally.  Aluminum is frustrating to cut with the original motor.Replaced the worm gear this year. Again 10 yrs old and run daily, not bad. We have a manufacture local, so that is incentive to hang on to the saw.  The swivel head is great.  I think it the measuring stick as to how much you want to pay.  The saw is just any other 5x6.  Good quality blade is a must.  .025" min thickness.
Reply:$500 seems high... I think Northern Tool sells their brand name for under $500 or right around there and I'm sure it's from the same factory.John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:ou think jet and northern are the same quality?face all times with a positive mental attitude,then and only then will you have done your best.
Reply:I've heard a lot of bad things about Jet's motors on those small band saws. I'm sure they pay more for additional quality control, and possibly some other features, but they're still both Chinese band saws.John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:so you think maybe 400 would be more reasonable? or go new northern?face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Looks like they're about $850 new off ebay. It does have a 1/2HP motor as compared to northerns 1/3HP. If you could get it for $300 I would say do that, maybe $400. Otherwise it's up to you. I've never used or even seen in person the Northern brand one but it looks to be about the same and has decent reviews plus a 1yr warranty. I have the South Bend version of this saw and I love it. Use it to miter pieces while my bigger saw cuts the "blanks".John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:$675 new Grizzly....all are made at the same place...http://www.grizzly.com/products/5-x-...vel-Head/G9742
Reply:is the difference in price quality or labeling..there's a 300-400 dollar sticker price difference between them all.face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Different HP motors, better casters, more quality control (less likely to have an issue), blade wheel bearings vs bushings, some come with a bi-metal blade others with carbon steel, etc... Lots of little things.John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:any of the one we helped show you is a better deal than this one...looks to be the same one as Bolton's, Grizzley's, and Northerns. But look at the price, man what a mark up !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!http://www.utilitybandsaw.com/trajan...e-band-saw.cfm
GMT+8, 2025-12-28 04:12 , Processed in 0.204813 second(s), 18 queries .
