Phantom Lite XL -Sellstrom
发表于 2021-8-31 23:10:49 | 显示全部楼层 |阅读模式
Hello guys, I bought this shield a while back and I have searched the internet several times and I cannot find inner or outer protective lens. Do any of you know where I could get a few from. I am going to try and post a pic if I can figure out how. Thanks in advance. Attached Images
Reply:I believe that one uses standard 4-1/2" x 5-1/4" lenses. You can buy those anywhere.John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:You're right. The outside is the regular 4-1/2 X 5-1/4. Now to figure out the inside size.
Reply:Originally Posted by BubbanSCYou're right. The outside is the regular 4-1/2 X 5-1/4. Now to figure out the inside size.
Reply:Actually it is a good bit smaller than the regular 5X4. I will walk to the shop in a few mins and measure it.
Reply:If the inside isn't a 2x4 take a 4x5 and set your old one on top and line up 2 sides. Score all the way across on 1 side with a utility knife and snap it off, repeat for the other side.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Originally Posted by AdvanI'd be shocked if the inside plate isn't also 4.5 X 5.25.....?
GMT+8, 2025-12-28 04:06 , Processed in 0.199133 second(s), 18 queries .
