Sst rod designation
发表于 2021-8-31 23:10:46 | 显示全部楼层 |阅读模式
OK, dumb guy here, well mostly forgetful. With a SST rod 310-16 what does the -16 mean? I have seen -15 & -17 before also… Isn’t that if it is easily run out of position or not? Many moons ago I knew all that info,,,, not so much anymore. I have been doing some searching, and have come up empty. I know the second I hit post I will find it…. But thanks in advance! TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:Missing,This link will answer your questions.http://www.lincolnelectric.com/asset...9L-17/c656.pdf
Reply:WELL DUH! IDIOT I AM...... Thanks for the help 4956!TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:If you are interested in what aws says check this out http://weldingweb.com/vbb/showthread.php...71#post3891571
Reply:Originally Posted by taz00If you are interested in what aws says check this out http://weldingweb.com/vbb/showthread.php...71#post3891571
GMT+8, 2025-12-28 02:13 , Processed in 0.196982 second(s), 18 queries .
