But I gave it a shot and I think it will work.A buddie at work has been rebuilding a 86 Honda ATV, every bearing in the front differential was toast. Could not locate this little pinion bearing anywhere. The one we DID find had the correct OD and thickness but the ID was too large. So What Would Zap Do? Weld it up and turn it down Just clean up pass.Forgot to get a pic of the weld before I started turning. I layed on 3 light passes letting it cool a bit between each one.TurningAnd it fits. Nice and snug not a press fit. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Oh yeah, and the socket I had to make to get this nut out just to GET to the little bugger If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Yo, sweet bro! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:You forgot the dime! How can you forget the dime???
Reply:Pretty slick. Any concerns that the case hardened gear may have been softened?
Reply:You used the wrong dial calipers. Zap! uses Chinese calipers, not American. Looks good.kidtigger24 They think Im crazy, but I know better. It is not I who am crazy. It is I who am MAD!
Reply:Originally Posted by kidtigger24You used the wrong dial calipers. Zap! uses Chinese calipers, not American. Looks good.kidtigger24
Reply:Is that a regular sized nut you welded to the socket? do you know the size? Im litterally doing the exact same thing on my fourwheeler.
Reply:Originally Posted by mlasal1Is that a regular sized nut you welded to the socket? do you know the size? Im litterally doing the exact same thing on my fourwheeler.
Reply:nice job on the repair!
Reply:Thanks, but dont worry about it. I doubt id bother to do all that. Ill put it back like i took it apart, hit it with a chisel round an round
Reply:plumbing sockets:Had to rebuild a Kawasaki diff that somebody had used too long of a helicoil in, which got broken off and trashed the bearings.
Reply:...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by forhirePretty slick. Any concerns that the case hardened gear may have been softened?
Reply:Originally Posted by MondoWould it help to weld something like this with some sort of hardfacing rod?- Mondo
Reply:Originally Posted by zapster.... turn the surface down about 1/4" and shrink a sleeve on it and that way you would keep the welding to a minimum......zap!
Reply:Originally Posted by zapsterAll that would do is turn into a nightmare when the turning part of our program started..If I knew exactly what you were doing Larp by the P/M'S I would have told ya to turn the surface down about 1/4" and shrink a sleeve on it and that way you would keep the welding to a minimum...I did not know you have a lathe at your disposal..All you would have needed to weld would have been the very end just to keep it in place..But it's done now so lets see how long it lasts..I'm guessing a VERY long time.....zap! |
